Hello Guest it is November 13, 2026, 11:29:15 AM
Author Topic: Can't get mach3 to home  (Read 18007 times)
« on: December 05, 2023, 02:04:12 PM »
I can't seem to get mach 3 to home.  My DRO's do not turn green and my soft limit doesn't turn green. I set the limit switches (X,Y to their coordinates and Z to its minus coordinate. I can get my machine to go to Zero, But  when hitting Ref to Zero my machine want to move only my Z axis to the limit switch and cause a hit limit switch to stop the machine. can't get the soft limit switch to turn green
Re: Can't get mach3 to home
« Reply #1 on: January 31, 2024, 03:16:12 AM »
Same issue! Did you find the solution? I tried checking the homing switch settings in Mach3 but everything is ok
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: February 06, 2024, 07:54:10 AM »
In ports and pins, disable all the axis limit switches and just have home switches enabled and try homing.
