Hello
Guest
it is
October 24, 2026, 03:47:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
MACH 3 connected with usb
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MACH 3 connected with usb (Read 29832 times)
wadeloud
4
on:
November 30, 2023, 09:27:29 AM »
Anybody using a usb connection to run mach 3 . I am having diffacultly getting my system to run properly.
Tweakie.CNC
9,374
Super Kitty
Re: MACH 3 connected with usb
Reply #1 on:
December 01, 2023, 12:25:33 AM »
Which motion controller are you using ? (ie. what is attached to your USB cable).
wadeloud
4
Reply #2 on:
December 01, 2023, 08:30:40 AM »
Wix Hc
Mach 3-USB Card
Cable connected to USB poer on Motion controller and pluged into a usb port on my computer.
JohnHaine
975
Reply #3 on:
December 01, 2023, 11:10:43 AM »
The controller should have an associated plugin which needs installing as described in the Mach3 manual. Do you have that? If not you will get nowhere. I use UC100 motion controllers with Mach3 and they work fine so it is possible.
wadeloud
4
Reply #4 on:
December 01, 2023, 11:30:34 AM »
thanks for your help
JohnHaine
975
Reply #5 on:
December 01, 2023, 11:48:30 AM »
I looked at the website and they don't mention a plugin anywhere as far as I can see - usually there would be a download or support area from which you can download it. It might have come on a CDRom or memory stick?
wadeloud
4
Reply #6 on:
December 01, 2023, 12:04:34 PM »
i got no software was my system.
JohnHaine
975
Reply #7 on:
December 01, 2023, 05:13:30 PM »
Well I think that's your problem, no Mach3 plugin. Ask the supplier.
Tweakie.CNC
9,374
Super Kitty
Reply #8 on:
December 01, 2023, 11:48:55 PM »
You need to copy the NcUsbPod.dll into your Mach3 / Plugins folder.
You can download the .dll from here;
https://www.cdxhctech.com/html/edownloads/220.html
JohnHaine
975
Reply #9 on:
December 02, 2023, 04:36:22 AM »
Good find Tweakie!
Print
Pages:
1
Go Up
« previous
next »
