Hello Guest it is October 24, 2026, 12:01:50 PM
Author Topic: MACH 3 connected with usb  (Read 29816 times)
« on: November 30, 2023, 09:27:29 AM »
Anybody using a usb connection to run mach 3 . I am having diffacultly getting my system to run properly.
  •  9,374 9,374
Re: MACH 3 connected with usb
« Reply #1 on: December 01, 2023, 12:25:33 AM »
Which motion controller are you using ? (ie. what is attached to your USB cable).
« Reply #2 on: December 01, 2023, 08:30:40 AM »
Wix Hc
Mach 3-USB Card
Cable connected to USB poer on Motion controller and pluged into a usb port on my computer.
« Reply #3 on: December 01, 2023, 11:10:43 AM »
The controller should have an associated plugin which needs installing as described in the Mach3 manual.  Do you have that?  If not you will get nowhere.  I use UC100 motion controllers with Mach3 and they work fine so it is possible.
« Reply #4 on: December 01, 2023, 11:30:34 AM »
thanks for your help
« Reply #5 on: December 01, 2023, 11:48:30 AM »
I looked at the website and they don't mention a plugin anywhere as far as I can see - usually there would be a download or support area from which you can download it.  It might have come on a CDRom or memory stick?
« Reply #6 on: December 01, 2023, 12:04:34 PM »
i got no software was my system.
« Reply #7 on: December 01, 2023, 05:13:30 PM »
Well I think that's your problem, no Mach3 plugin.  Ask the supplier.
  •  9,374 9,374
« Reply #8 on: December 01, 2023, 11:48:55 PM »
You need to copy the NcUsbPod.dll into your Mach3 / Plugins folder.
You can download the .dll from here; https://www.cdxhctech.com/html/edownloads/220.html
« Reply #9 on: December 02, 2023, 04:36:22 AM »
Good find Tweakie!
