Hello Guest it is October 24, 2026, 02:50:33 PM
Author Topic: Increasing the number of user defined inputs in Mach3  (Read 23942 times)
« on: November 01, 2023, 06:28:53 PM »
Hello,
I am installing an ATC into my system of a PDMX125 BOB with a USS attached (using both parallel ports).
All the hardware is installed and all sensors attached with ports/pins defined.
Within the Mach3 config/inputs, there is only 4 user defined inputs ie. input#1, input#2, etc...,
can this number be increased, input#5, input#6 etc..? I have already used the 4 existing inputs for other sensors.
I have a situation where I need 4 more inputs:
1) tool magazine fully opened Port 3 pin 1
2) tool magazine fully closed Port 3 pin 2
3) tool holder fully inserted into spindle port 3 pin 3
4) tool holder fully released from spindle port 3 pin 4
Somehow I need to establish a link with an input name and the port/pin for the M6 macro.
Can this relationship be established within the program or somewhere else within Mach3?
I have searched the net with no results, surely this must be a common situation!!!
Thanks for any help.
Chris
Offline TPS
  •  2,627 2,627
Re: Increasing the number of user defined inputs in Mach3
« Reply #1 on: November 11, 2023, 02:56:48 AM »
you can also assign
OEM Trig#1 to OEM Trig#15 and use the as "normal" Inputs like Input1-4
