Hello Guest it is October 20, 2026, 03:01:01 PM
Author Topic: Mach's Keyway Wizard  (Read 12531 times)
« on: November 09, 2007, 07:26:05 AM »
I'm asking Mach's Keyway Wizard to cut .26 width with a 1/8 endmill but only get  1/8 slot. The gcode shows no change in y.  I can't figure out what I'm doing wrong. Could you get me back on track? Thank you,  Shepard
vmax549
Re: Mach's Keyway Wizard
« Reply #1 on: November 09, 2007, 08:36:00 AM »
Shepard I just ran a simulation and what I saw was that it first cut a center .125 slot down the center, it then did a pocket of the slot width to clean it up and repeated until the depth of cut was reached. Did you actually run the file or just look at the code?
« Reply #2 on: November 09, 2007, 09:16:09 AM »
I'm an idiot. Thank you. I had not let the file get to the pocket.
« Reply #3 on: May 30, 2011, 10:56:23 PM »
I  cut 2  .250 wide key ways today and  the machine left  a ramp on the opisite side of the ramping of the program but the D.R.O. was going to the right  count every time
any idea what  is wrong
