Hello Guest it is September 30, 2026, 03:37:46 AM
Author Topic: Saving Mach3 files in Vectric Desktop  (Read 29663 times)
« on: October 07, 2023, 05:47:09 AM »
Hi Guys. My first ever post, not sure I am in the right place, trying to save a .tap file in Vectric desktop, there is no option showing Mach3 in tap format, i have used .tap previously but recently changed to new PC win10 and USB just got it running after months of trying, for anyone struggling to set up the Break out board with USB, because the BOB i am using has auto levelling you need to put all your homing switches on separate inputs and unfortunately there are only 4, My auto tool height setter has to go. Also remember that the input side also uses port 3.
  •  9,374 9,374
Re: Saving Mach3 files in Vectric Desktop
« Reply #1 on: October 07, 2023, 05:53:01 AM »
No need for .tap format as Vectric will save GCode files as .txt which is acceptable for input to Mach3.
« Reply #2 on: October 07, 2023, 11:56:16 AM »
Many thanks Tweakie. Strange that i have been using .tap for years.
Fogster
  •  9,374 9,374
« Reply #3 on: October 08, 2023, 03:44:59 AM »
If you prefer .tap then you could always edit the Post Processor that you are using (it will be in the C: / Users / All Users / Vectric... directory) to change the FILE_EXTENTION from "txt" to "tap". Vectric will then save the GCode file with the .tap extention.
Just a thought.
« Reply #4 on: October 09, 2023, 04:46:48 AM »
Great idea. Many Thanks Fogster
