Hello Guest it is November 22, 2026, 07:29:13 AM
Author Topic: RnRMotion Boards and Lathe Threading  (Read 28112 times)
« on: August 12, 2023, 02:05:09 PM »
Hello all,
I am looking for a bit of help, I have an old Denford Starturn 4 (1990) that I wish to convert and as its a bit scruffy its not worth spending a fortune on so economy is the way forward.
My question, do any of the RnRMotion boards work with a lathe, e.g. can I input the spindle pulse for threading?
YP
Re: RnRMotion Boards and Lathe Threading
« Reply #1 on: August 13, 2023, 04:44:19 AM »
Sorry I don't think that board will do what you want. Here is a little info on it though.
https://buildyourcnc.com/item/electronicsAndMotors-electronic-component-breakout-Mach3-USB-Board
Regards
Charlie M.
« Reply #2 on: August 13, 2023, 09:53:11 AM »
Thanks for the reply, I checked out the page and as per all the ones I have looked at there is no definitive yes or no on threading but lots of general inputs.
I know I can use LPT port but that makes using a modern PC a problem.
Any suggestions welcome.
YP
« Reply #3 on: August 13, 2023, 11:22:26 AM »
Regards
Charlie M.
« Reply #4 on: August 13, 2023, 11:35:08 AM »
Or indeed the UC100
« Reply #5 on: August 13, 2023, 01:25:50 PM »
I'm not sure if the uc100 supports spindle input.
Regards
Charlie M.
« Reply #6 on: August 13, 2023, 03:26:45 PM »
Sure does.
