Hello
Guest
it is
November 19, 2026, 04:16:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
LazyCam=>MACH 3 need help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: LazyCam=>MACH 3 need help (Read 11931 times)
gbecerra
4
on:
November 07, 2007, 02:14:28 PM »
Hello
My problem is that I can only import 50 cutting points to MACH 3 from LazyCam. When I export the DXF file into LazyCam the cutting path shows correctly but when I export the LazyCam File (G-Code) into MACH 3 it shows incomplete. The pattern I have found is that I can only export 50 cutting points in to Mach 3. So, cutting paths greater than 50 points are not exported into MACH 3.
The version of I am using is MACH 3 R2.48 demo version.
I need help tracing this problem? I don't know if it is LazyCam or MACH 3 related?
Thank You in advance for your help.
Logged
Chip
2,055
Gainesville Florida USA
Re: LazyCam=>MACH 3 need help
Reply #1 on:
November 10, 2007, 01:24:39 AM »
Hi, Gbecerra
MachLic.data-file, $160.00 Removes the 500 or 1000 line limit from Mach depending on version and turns on some other items, I don't have a list.
LazyLic.data-file, $75.00 allows offsetting, pocketing and turn features.
Thanks, Chip
Last Edit: February 27, 2008, 01:46:20 PM by Chip
Logged
buddy
1
Reply #2 on:
February 27, 2008, 12:58:08 PM »
I can only get about 600 lines of G-code to Mach 3. In Mach 3 I can't find the Mach 3.exe file. I this my problem, or what do I need to do. Thks. Don
i
Logged
Chip
2,055
Reply #3 on:
February 27, 2008, 02:03:51 PM »
Hi, Don
If you don't have a Mach3 license, "MachLic.data-file" in C:\Mach3 folder, You'll only be able to run 500 lines of code.
Thanks, Chip
Logged
Print
Pages:
1
Go Up
« previous
next »
