Hello Guest it is October 21, 2026, 07:25:48 AM
Author Topic: Mach 4 toolpath not smooth in screen  (Read 6394 times)
Offline ROTM
  •  24 24
« on: July 05, 2023, 05:17:12 PM »
Good day.
I am exporting a file...svg into sheetcam and then export as .tap file to Mach4.
However in Mach 4 screen the toolpaths are not as smooth as in sheetcam.
I just replaced a new PC with a fresh install of Mach4 ...adn on the old pc it was just fine..
Regen does not do anything...also is there a way to make the toolpath lines in the screen a bit thicker?
Thank you!
Offline smurph
  •  1,575 1,575
Re: Mach 4 toolpath not smooth in screen
« Reply #1 on: July 07, 2023, 03:41:48 PM »
This has EVERYTHING to do with the OpenGL support in you video card driver.  See if there is an updated driver available for your GPU.
Steve
Offline Stuart
  •  311 311
« Reply #2 on: July 08, 2023, 01:30:51 AM »
further to Steve's comment
new pc ? I will bet a £ to a pinch of Salt that the new PC has integrated graphics , not a proper GPU
I had the same problem with a Dell opitplex SFF I got a GPU that fitted into the PCI slot and result smooth graphics
