Hello
Guest
it is
October 21, 2026, 07:25:47 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach 4 toolpath not smooth in screen
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 4 toolpath not smooth in screen (Read 6394 times)
ROTM
24
on:
July 05, 2023, 05:17:12 PM »
Good day.
I am exporting a file...svg into sheetcam and then export as .tap file to Mach4.
However in Mach 4 screen the toolpaths are not as smooth as in sheetcam.
I just replaced a new PC with a fresh install of Mach4 ...adn on the old pc it was just fine..
Regen does not do anything...also is there a way to make the toolpath lines in the screen a bit thicker?
Thank you!
Logged
smurph
1,575
"That there... that's an RV."
Re: Mach 4 toolpath not smooth in screen
Reply #1 on:
July 07, 2023, 03:41:48 PM »
This has EVERYTHING to do with the OpenGL support in you video card driver. See if there is an updated driver available for your GPU.
Steve
Logged
Stuart
311
Reply #2 on:
July 08, 2023, 01:30:51 AM »
further to Steve's comment
new pc ? I will bet a £ to a pinch of Salt that the new PC has integrated graphics , not a proper GPU
I had the same problem with a Dell opitplex SFF I got a GPU that fitted into the PCI slot and result smooth graphics
Logged
Print
Pages:
1
Go Up
« previous
next »
