Hello Guest it is October 20, 2026, 09:52:53 PM
Author Topic: Mach3 demo jog continious and jog step directions different  (Read 24272 times)
I have just installed and set up Mach3 demo  mill on a XP platform.  Set up axis's and axis's directions correctly per jog continuous but when I change to single step they jog the wrong direction  ie the X+ button moves the axis X- direction when in single step.  When "all homing" the directions are fine.  Are there separate parameters for the step directions?
Re: Mach3 demo jog continious and jog step directions different
« Reply #1 on: June 07, 2023, 09:23:10 AM »
Trevor in support helped a lot.   In the pin menu motor settings  there is a column heading "Step Dir A"  which I now take as "Step Direction Active".  I changed each axis to green check mark and that solved the problem.
Thanks again
Trevor
