Mach Discussion => General Mach Discussion => Topic started by: redd103 on June 05, 2023, 06:45:23 PM
I have just installed and set up Mach3 demo mill on a XP platform. Set up axis's and axis's directions correctly per jog continuous but when I change to single step they jog the wrong direction ie the X+ button moves the axis X- direction when in single step. When "all homing" the directions are fine. Are there separate parameters for the step directions?
Trevor in support helped a lot. In the pin menu motor settings there is a column heading "Step Dir A" which I now take as "Step Direction Active". I changed each axis to green check mark and that solved the problem.
Thanks again
Trevor
