Hello
Guest
it is
October 20, 2026, 04:55:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Problem with extra Parrallelports
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problem with extra Parrallelports (Read 21261 times)
Dave_SWE
on:
April 12, 2006, 06:31:33 AM »
Hi!
I have problems with i Parrallelcard that I have bought. It contains 2 ports and I want to use that for all cnc-control. I have a working machine now that I run from the computers builtin parrallel port.
I cant find which portadress to use. When I check the card it uses I/O BC00-BC07, B800-B807, B400-B407, B000-B007,AC00-AC07, A800-A80F.
The adresses isnt changeable and the ports are configured as LPT2 and 3 and ECP.
The card is a VScom PC1021H-EP2.
Is it even possible to use this card with mach and if it isnt what card should I buy that works?
Thanx!
David Larsson
Brian Barker
3,860
Re: Problem with extra Parrallelports
Reply #1 on:
April 13, 2006, 11:45:25 AM »
Hello Dave,
All you have to do is type in one of the BC00-BC07, B800-B807, B400-B407, B000-B007,AC00-AC07, A800-A80 into the ports in Mach3. You will have to test each one to figure out what one is going to work
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Dave_SWE
Reply #2 on:
April 13, 2006, 04:34:08 PM »
Is it that easy? Well thanx I´ll do that!
Just thought that it wouldnt work cause it suddenly got 4 after the 0x...
Just wanna give Art a big "thank you" for the program! I´ll convince my boss that we need a full version of this so that you get payed for your hard work! I have converted an old Cortini mill from 2D to 3D on just 2days thanx to your program!
Dave_SWE
Reply #3 on:
April 19, 2006, 01:06:18 AM »
Hi again!
Well I´m sorry to say that it didnt work. I tried every adress that where in the config and I got some response from the machine at one adress but it didnt move. The response I got was in form of when I pressed a button that should move one axel the machine sounded different. But it didnt move.
And a question thats of topic... Is it on g-rex 101 possible to run the spindle with one of the analog outputs? My spindle needs a signal that differs betwen 0-6V depending on what rpm you need. If it works I will consider buying a g-rex instead cause that will solve all my problems.
Thanx!
/David
Brian Barker
3,860
Reply #4 on:
April 19, 2006, 07:10:58 AM »
IT should work .... I have not tested that becuase I am running my spindle with a PLC
www.machsupport.com
Cortini
1
Stefan
Reply #5 on:
October 07, 2008, 10:13:44 AM »
Hej David.
Jag svarar inte på ditt problem. Vill få kontakt med dig. Jag har en Cortini L 300.
Stefan
SteJo
Print
Pages:
1
Go Up
« previous
next »
