Hello Guest it is October 21, 2026, 02:05:14 AM
Author Topic: Feed rate issue Mach 3  (Read 30073 times)
« on: April 11, 2023, 11:54:38 PM »
Hello everyone,
I`m having one problem with my CNC Router. When I make my G-code I set the feed rate F4610 but on my Mach 3 screen, the feed rate is between 800-1000 never over 1000.
Motor tuning is set up to 7000. Is there any solution?
Here is an example of the G-code:
M5
M9
T2 M6
S21000 M3
G54
M8
G0 X-743.5 Y1276.162
G43 Z33. H2
Z23.
G1 Z20.5 F800.
Y1405.025 Z16. F4610.
Y1521.55
Y1526.55
X-348.5
Y763.55
X-743.5
Y1405.025
G0 Z23.
X-614.637 Y1529.6
G1 Z20.5 F800.
X-743.5 Z16. F4610.
Y2287.6
Y2292.6
X-348.5
Y1529.6
X-743.5
G0 Z23.
X-188.45 Y1533.888
G1 Z20.5 F800.
Y2.5
Y-2.5
X-345.45
Y2304.5
X-188.45
Y1405.025
Re: Feed rate issue Mach 3
« Reply #1 on: June 11, 2023, 10:58:47 PM »
I was wondering if anyone has successfully used Mach3 with a 5 axis trunnion system.
« Reply #2 on: June 12, 2023, 03:44:25 AM »
I suspect that you would get a quicker answer if you posted a new thread with a title like "Mach 3 5-axis trunnion system"
« Reply #3 on: June 12, 2023, 03:49:01 AM »
Hello everyone,
Do you really need to feed at 4.6 metres/minute?  Or inches/minute?
« Reply #4 on: June 12, 2023, 04:22:27 AM »
It could also be that at over 1000 units/min you would exceed the pulse rate available from your motion controller.
