Hello Guest it is October 02, 2026, 06:55:58 AM
Author Topic: How can I enter a 7 digit integer number into a DRO  (Read 24907 times)
« on: March 22, 2023, 04:33:38 PM »
Hi all,
I am making a custom screen for my brother and he needs to be able to enter a 7 digit integer number into a DRO.
I have tried and the most I can enter is 123456
I can enter 0.1234567 but then the operator has to remember to do this or scrap the part.
Has anybody any ideas?
« Last Edit: March 22, 2023, 04:35:22 PM by Yorkshire Pudding »
Offline TPS
  •  2,627 2,627
Re: How can I enter a 7 digit integer number into a DRO
« Reply #1 on: March 23, 2023, 02:20:02 AM »
i you use machscreen:
https://kd-dietz.com/pages/eng/machscreen/description.html
you can enter the format you want to use for a dro input field.
« Reply #2 on: March 23, 2023, 11:08:31 AM »
I use Machscreen too and while creating the DRO you can indeed enter 7 leading digits and zero trailing digits but once you load the screen into Mach3 you can only enter 6 digits.
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 23, 2023, 12:19:41 PM »
OK,
sorry did no test.
i think we have to wait for Klaus to show up, he is the screen specialist.
« Reply #4 on: March 24, 2023, 04:28:10 AM »
Hi
I'm sorry, I can't help in this case. Mach3 limits integer numbers to 6 digits. I wouldn't know a solution for that issue. I will check that in next version of MachScreen.
Klaus
The brain isn't a soap, it doesn't shrink when used.
