Hello Guest it is November 13, 2026, 09:40:23 AM
Author Topic: Mach3 not saving fixture settings  (Read 24066 times)
« on: March 16, 2023, 07:37:51 PM »
Mach3 is not saving axis positions when closing out.  It has worked fine for 6 or so years that I have been using this program.  I loaded a new profile and everything, so far anyway, has worked normal.  It is kind of important for this feature to work as many of my projects run over three or four work days.
Ed
Offline TPS
  •  2,627 2,627
Re: Mach3 not saving fixture settings
« Reply #1 on: March 17, 2023, 03:11:47 AM »
Config -> General Config -> Axis DRO properties -> Persistent Offsets
« Reply #2 on: March 17, 2023, 12:35:35 PM »
Thanks, TPS.  Persistent offsets is checked.  Persistent DROs is not checked.  Optional offset save is checked.  I guess I'll check/uncheck until it works.
Ed
