Hello Guest it is October 22, 2026, 03:41:29 PM
Author Topic: I don't see the "SIMULATOR" tab  (Read 12868 times)
« on: March 13, 2023, 06:02:06 AM »
I instal Simulator moduleWorks and enabled the simulator plugin and uploaded the license, but I don't see the "SIMULATOR" tab, how to set it.
Re: I don't see the "SIMULATOR" tab
« Reply #1 on: March 13, 2023, 09:19:53 PM »
not exactly sure what you mean. Mach4 does have a Simulation Device but you don't need a license, and you don't need to download it, its part of every
Mach4 build....its already there.
« Last Edit: March 13, 2023, 09:32:00 PM by joeaverage »
« Reply #2 on: March 14, 2023, 02:38:32 AM »
I have 3D simulator, and i can see how part luk like after mill. I insert these like new tab, its work.
« Reply #3 on: March 14, 2023, 03:00:20 AM »
kool, tell us how it works.
I have a fourth axis but the toolpath display is fine for tree axis but crap for four. I'm building a fifth axis and it sure would be nice to see a
3D render of the toolpath.
« Reply #4 on: March 14, 2023, 04:31:31 AM »
This plugin allows a user to run a 3 Axis cnc Mill or Router. I take screen how it work for mee, by fiew days.
« Reply #5 on: March 14, 2023, 06:51:35 AM »
Craig:
The ModuleWorks simulator is available for purchase on the Machsupport.com web site.
It supports 3 axis milling and would not help with 4 or 5 axis systems.
It installs as a separate Mach4 profile as if it was another machine.
https://www.machsupport.com/shop/3d-cutting-simulator-mach4-hobby-plugin/
Steve Stallings
www.PMDX.com
« Reply #6 on: March 14, 2023, 06:54:05 AM »
I take these to mill profile like a tag.
« Reply #7 on: March 14, 2023, 07:04:13 AM »
Craig:
ModuleWorks.com does offer 4 and 5 axis simulators for other partners. They have done simulators for dozens of companies and you may have seen their software being used by dental labs that make prosthetics. Perhaps you could investigate the possibility but it will likely be much more expensive.
Steve Stallings
www.PMDX.com
Re: I don't see the "SIMULATOR ModuleWorks" tab
« Reply #8 on: March 14, 2023, 09:26:16 AM »
See attachment. The operating material is now displayed in the simulator field. But why no tool? When I disconnect the ethernet, the tool is visible, but I can't turn on machining. When ethernet is connected there is no tool. What to do? I can't simulate without the tool  >:D
« Reply #9 on: March 14, 2023, 05:12:14 PM »
Hi Steve,
thanks for the clarification.
Crikey.....I'm still reeling from the thousands spent on the hardware for my fourth axis ($2000NZD)  and the hardware investment for
the fifth axis ($1700NZD and counting), not looking to spend any more money at the moment, and may not ever again!! ;D
