Hello Guest it is October 22, 2026, 08:03:56 PM
Author Topic: Mach4 and Y axis gantry travel / configuration  (Read 5939 times)
« on: March 12, 2023, 03:18:12 PM »
I have an Avid CRP4896 (Standard, not Pro).  I installed Mach4 and in the "Tool Preview" the Y axis indicates and will only travel 24".  I checked the configuration and for some reason it changed from 96' to 24", which would make sense as to why it is traveling only 24". I changed the setting to 96", saved the configuration, but it still only travels 24".  Do I need to re-install Mach4?  Can I create a "New" profile?  Any/All input is appreciated!!
Re: Mach4 and Y axis gantry travel / configuration
« Reply #1 on: March 13, 2023, 12:44:27 PM »
It may be a soft limits thing.  I'm not sure how much you can do with Avid's stuff with mach4.  If you can get into the "Configure --> Control" you can check in the Homing and limits tab to see if the axis soft limits are still set to 24"
Chad Byrd
