Mach Discussion => Mach4 General Discussion => Topic started by: DblDogDare on March 12, 2023, 04:18:12 PM
I have an Avid CRP4896 (Standard, not Pro). I installed Mach4 and in the "Tool Preview" the Y axis indicates and will only travel 24". I checked the configuration and for some reason it changed from 96' to 24", which would make sense as to why it is traveling only 24". I changed the setting to 96", saved the configuration, but it still only travels 24". Do I need to re-install Mach4? Can I create a "New" profile? Any/All input is appreciated!!
It may be a soft limits thing. I'm not sure how much you can do with Avid's stuff with mach4. If you can get into the "Configure --> Control" you can check in the Homing and limits tab to see if the axis soft limits are still set to 24"
