Hello Guest it is October 24, 2026, 03:47:42 PM
Author Topic: Double Ethernet cards conflict  (Read 22845 times)
« on: January 20, 2023, 08:01:46 AM »
Good morning everyone !
I'm using Mach3 with a PC that has 2 ethernet cards. One of the 2 is used for the CS-LAB controller while the other is used for ordinary network management and for sending files to the PC. The 2 boards are in conflict with each other, how can I fix it? If I disconnect the second card and use a Wifi, everything works fine. Thank you
Offline reuelt
  •  520 520
Re: Double Ethernet cards conflict
« Reply #1 on: January 20, 2023, 02:34:36 PM »
The ethernet card for CS-lab controller and the controller should have manually assigned IP addresses of another subnet and without a default gateway (leave blank).
"the gift of God is eternal life through Jesus Christ our Lord"
