Hello Guest it is November 11, 2026, 11:05:22 PM
Author Topic: HELP Mach 3 wont move  (Read 86423 times)
« on: January 12, 2023, 01:06:12 PM »
Hello all,
I am fairly new to mach 3, but have cnc background. I had my computer crash that was running our  Taping machine, i was able to save the Mach 3 folder from the c:/ off the old hardrive.
My plan is to rebuild a new computer to run the machine but i am waiting for the ESS to show up, in the meantime to not lose production i found an old computer upstairs that had Windows XP (the same software as the computer that crashed). I downloaded Mach3 onto it and loaded all the old settings (whole Mach 3 folder from old harddrive).
My issue is that Mach 3 will load and i looked at the config and everything matched the old settings, but i cannot get the machine to move. Even the numbers in the axis wont move.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: HELP Mach 3 wont move
« Reply #1 on: January 12, 2023, 06:16:12 PM »
Check that the parallel port IRQ is correct, go to hardware settings and check the LPT config.
Go to Diagnostics screen and check the pulse rate is not Simulated.
« Reply #2 on: January 13, 2023, 08:12:19 AM »
I checked the LPT port it is 378 and it matches the port # in mach.
I went to diagnostics and i try and jog and i have no movement or lights lighting up. I did do a m03 to start the spindle and the spindle light lit up but no movement on the spindle.
  •  2,785 2,785
« Reply #3 on: January 16, 2023, 06:51:30 AM »
Did you check the you have a pulse rate showing or did it say simulated?
« Last Edit: January 16, 2023, 06:53:19 AM by Graham Waterworth »
« Reply #4 on: January 19, 2023, 12:56:46 PM »
I reinstalled Mach3 and reset up all he ports and pins, and now the machine is working. Thanks for the help
« Reply #5 on: March 24, 2023, 10:58:55 AM »
Dear sir/ma
How can I make CNC machine to engrave fast with mach3 controller
