Hello Guest it is October 11, 2026, 11:59:05 AM
Author Topic: XBox 360 Plugin - Can't get it to work or recognize  (Read 34586 times)
« on: December 29, 2022, 02:43:20 PM »
Hello All,
Trying to use the plugin made by @dazthegas for the XBox 360 Controller.  Have some weird issues, wondering if someone can give some advice.  I have the plugin in the plugins directory.  I can activate the plugin from the Configure -> Control->Plug in menu. However here is where it gets a bit weird for me.  I do NOT see the plugin under Configure->Plugins.  Also it does not show me that the XBox 360 Controller is active in the message bar. I am on Windows 10 running the latest version of Mach4.  Another weird thing is that if I check the controller from Diagnostic->Regfile it DOES show signals from the controller.  I am sure it is something simple, but I can't seem to figure this one out.  I've reinstalled, restarted, etc... no joy.
Thanks!
Re: XBox 360 Plugin - Can't get it to work or recognize
« Reply #1 on: December 30, 2022, 01:40:43 AM »
I use the controller with Mach3 under Win10 and found that you need to reinstall some windows components (ActiveX?) that Win10 doesn't normally have.  This came up recently and I posted a link to the fix iirc.
« Reply #3 on: December 30, 2022, 08:10:06 AM »
Thank you very much for the reply JohnHaine!  I am proceeding as suggested however after the DirectX install I cannot find "xbox.dll".  Where is that file?  Thanks.
« Reply #4 on: December 30, 2022, 09:08:57 AM »
Attached photo may help - it's in the Mach3 plugins folder, may be different for Mach4.  There is a copy in my downloads folder so I presumably downloaded it from somewhere...
« Reply #5 on: December 30, 2022, 09:25:17 AM »
I can't find that file anywhere on my computer.  Searching Google for the exact filename ....
« Reply #6 on: December 30, 2022, 09:29:37 AM »
I could send you a copy?
« Reply #7 on: December 30, 2022, 09:34:39 AM »
That would be awesome.  Thanks for the offer.  Can we do it here or in a PM?
« Reply #8 on: December 30, 2022, 09:35:35 AM »
I am wondering if it is a native Windows dll or something DazTheGas made?
« Reply #9 on: December 30, 2022, 09:41:52 AM »
I found it on the Mach3 Plugins page :-).
