Hello Guest it is October 11, 2026, 12:56:32 PM
Author Topic: XBox 360 Plugin - Can't get it to work or recognize  (Read 34594 times)
Re: XBox 360 Plugin - Can't get it to work or recognize
« Reply #10 on: December 30, 2022, 02:11:18 PM »
Ok.  I am getting somewhere slowly.  I am using some debug output messages to trace the LUA script functionality.  For some reason, at least on my system, I need to explicitly define the number variable on both sides of an if statement operator.
For example, this does NOT work:
LTR_Val = GetXin("LTR_Val") --left trigger value 0-255
if LTR_Val > 0 then
   mc.mcCntlSetLastError(mInst,"LTR_Val not 0")
elseif LTR_Val == 0 then
   mc.mcCntlSetLastError(mInst,"LTR_Val 0")
end
However this DOES work:
if tonumber(LTR_Val) > tonumber(0) then
elseif tonumber(LTR_Val) == tonumber(0) then
end
« Reply #11 on: December 30, 2022, 02:26:03 PM »
I also found that I have to first assign the trigger value to a variable before putting into a logical statement. Example:
