Hello Guest it is October 22, 2026, 05:10:52 PM
Author Topic: Cant get motors to turn  (Read 22557 times)
« on: December 22, 2022, 01:50:42 AM »
can anyone give me a clue to what I can do to get the axis motors to turn. They are locked solid to the rails. The spindle works fine
Mach4 V4.2.0.5 Licensed
ESS v284 with MB3-BOB
Old avid 2448 with custom electronics
New Spindle and Huanyang VFD
Ive attached my profile (MyCNC_Testing.zip)
Re: Cant get motors to turn
« Reply #1 on: December 22, 2022, 01:15:41 PM »
going to need a bit more information .
When you power up Mach4 does the ESS start communicating as signalled by the LEDs on the ESS?
Does the MB3 generate output signals, in particular does it have LEDs on the axis drive Step/Dir outputs?
The MB3 has differential Step/Dir outputs....how have you wired them to the axis drives?
What are the axis drives?
Do the axis drives require/have the required Enable input?
Re: Cant get motors to turn - stupid mistake
« Reply #2 on: December 27, 2022, 12:25:28 AM »
I didn't have the db24 cable grd pin connected. All is good Thanks
