Hello Guest it is July 17, 2025, 07:49:23 PM
Author Topic: probe won't retract  (Read 38206 times)
probe won't retract
« on: December 08, 2022, 03:39:36 PM »
I'm running Mach4 on a router and it works great except probing. When I try to touch off a new tool, it lowers and resets the tool height properly but fails to retract. Is there a solution? The probe is always live and when the tool touches it drops the voltage. I tried noise filtering but that didn't help.
Re: probe won't retract
« Reply #1 on: December 11, 2022, 03:49:14 PM »
can you show us the code?
A G31 probing move requires two Gcode moves, namely the G31, which is dynamically the same as a G1 move, ie linear interpolation at the prevailing feed rate,
followed by a G0 which is to retract the tool.
Unlike a home switch Mach does not automatically retract the tool from a probe event, you have to code it specifically.
« Reply #2 on: December 12, 2022, 10:43:39 AM »
I tried a few codes, lately I was using the touch button.
The basic code would be:
 G31 Z-1 F10
 G90 G1 Z1 F50
Something like that, I think I tried a G90 in front of the G31.
However, the program disables as soon as the probe touches so it can't retract. Also, I have to override the axis limits to move it off the probe so it won't retract anyway. However, I think there should be a Gcode for that I just don't know it.
« Reply #3 on: December 12, 2022, 02:26:41 PM »
this is an excerpt from a probing routine that I use:
Code: [Select]
M40 (Begins a probe log file, when the window appears, enter a name for the log file such as "RawProbeLog.txt")
G0 Z2
G1 X-0.589 Y1.5875 F1000
G31 Z-1 F100
G0 Z2
G1 X10.50726 Y1.5875 F1000
G31 Z-1 F100
G0 Z2
G1 X21.60352 Y1.5875 F1000
G31 Z-1 F100
G0 Z2
G1 X32.69978 Y1.5875 F1000
G31 Z-1 F100
G0 Z2
G1 X43.79604 Y1.5875 F1000
G31 Z-1 F100
G0 Z2
G1 X54.8923 Y1.5875 F1000
G31 Z-1 F100
G0 Z2
G1 X54.8923 Y11.67083 F1000
G31 Z-1 F100
G0 Z2
G1 X43.79604 Y11.67083 F1000
G31 Z-1 F100
G0 Z2
G1 X32.69978 Y11.67083 F1000
G31 Z-1 F100
G0 Z2
G1 X21.60352 Y11.67083 F1000
G31 Z-1 F100
G0 Z2
G1 X10.50726 Y11.67083 F1000
G31 Z-1 F100
G0 Z2
G1 X-0.589 Y11.67083 F1000
It works perfectly and dozens of other probing routines almost identical to it and has done for eight years. You need to look at your code.
What motion controller are you using? If its an ESS then you need to save a log file. I suspect that the probe data is not being sent to Mach
and therefore the G31 move never completes, and cannot progress to the following G0 retract move.
« Reply #4 on: December 13, 2022, 09:45:30 AM »
I went out and tried that.. I tried to start Mach but got an error.
« Reply #5 on: December 13, 2022, 12:19:37 PM »
the first error is because Mach cannot find or load an ESS plugin. Do you even have an ESS?
The second error is because you don't have an m40 macro to record the probe data.
Just because I gave you an excerpt does not mean it will run on your machine, but rather it was to show the naure of the
code required.
« Reply #6 on: December 13, 2022, 02:26:02 PM »
Thanks Craig
I restarted my computer and now it works again. Sorry for all that trouble
The code was practically identical to what I use, but I tried it anyway, with a few parameters changed for my machine, but got the same result.
Is it supposed to disable on probe touch?
Or should I use a different probe voltage? My tester showed 21v at the ESS.
« Reply #7 on: December 13, 2022, 03:22:19 PM »
21V at the ESS means the ESS is f*********ed! The ESS is 5V input and output, I would not risk as little as 5.1V
You should have a breakout board to handle the probing that has protection circuits to prevent extraneous voltages from ever reaching
the ESS.
You should try MDIing some probe cycles.
« Reply #8 on: December 15, 2022, 11:25:39 AM »
Thanks Craig,
"21V at the ESS means the ESS is f*********ed! The ESS is 5V input and output, I would not risk as little as 5.1V"
If this is the case, why is the ESS still working?
The machine works fine except for that one issue.
I tried dropping the voltage, but then the probe randomly activated and deactivated.
I also tried MDIing the probe.
I'm sorry if I don't make sense, I just want to understand what's going on.
« Reply #9 on: December 15, 2022, 02:35:18 PM »
If you apply more than 5V to an ESS input you will blow that input for sure. Don't do it.
You should have a breakout board to do the probing which has protection to prevent ANY excess voltage from reaching the ESS.
