Hello
Guest
it is
July 18, 2025, 05:43:32 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
probe won't retract
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: probe won't retract (Read 38217 times)
cnc addict
11
Re: probe won't retract
Reply #10 on:
December 15, 2022, 03:02:21 PM »
I'm using a CNC4pc board. The guy who ordered it thought it was just an ESS but it looks like maybe it is a breakout board with an ESS installed?
Sorry I don't know more about the board, but the guy who did most of it quit, and the owner wanted me to finish it
Here is a link to the board's webpage:
https://www.cnc4pc.com/c25xp-smooth-stepper-integrated-board.html
Logged
joeaverage
7,606
Reply #11 on:
December 15, 2022, 03:53:32 PM »
so where are you measuring the voltage, at the input of the breakout board OR the ESS?
Logged
cnc addict
11
Reply #12 on:
December 15, 2022, 03:57:56 PM »
At the input of the breakout board.
Logged
joeaverage
7,606
Reply #13 on:
December 15, 2022, 05:04:53 PM »
OK, phew!!! I am assuming the breakout board will reduce the probe voltage to a max of 5V.
When you operate the probe manually does the probe LED on the Mach4 screen light and un-light?
Logged
cnc addict
11
Reply #14 on:
December 16, 2022, 08:13:33 AM »
Yes, the probe LED will light and un-light, and whenever the probe LED lights, Mach4 disables- then with the probe active and I can re-enable it and it stays enabled.
Logged
cnc addict
11
Reply #15 on:
December 20, 2022, 09:04:14 AM »
Thanks for all your help. I just found the L82 command and went out and tried that and it worked. Thanks again for all your help.
Logged
cnc addict
11
Reply #16 on:
December 21, 2022, 06:10:01 AM »
I just discovered that L82 was simply going down and almost touching the probe. If it touches, Mach disables like it does for G31. So I guess I'm back in square 1.
Logged
cnc addict
11
Reply #17 on:
August 29, 2024, 08:48:22 PM »
Thanks for your help. A professional was brought in to finish it and it probes correctly now. Not sure what he did.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
