Hello Guest it is November 13, 2026, 11:05:19 AM
Author Topic: Cambiador de herramientas automatico y seleccion de servomotor  (Read 22303 times)
« on: December 02, 2022, 11:00:50 AM »
Buenos dias amigos,
disculpen, estoy diseñando mi cnc grande en el cual me gustaria saber si alguien me podría apoyar o guiar que codigo o macro me recomiendan para hacer el cambio de herramientas automatico, tengo pensado utilizar un atc bt30, por cierto creen que un servomotor de 1000w 3.3n.m 3000rpm sea buena opcion para cortar acero y aluminio? o esta muy chico?, utilizaria poca profundidad de corte, espero me puedan orientar de antemano muchas gracias amigos
Good morning friends, excuse me, I'm designing my large cnc in which I would like to know if someone could support me or guide me that code or macro recommend me to make the automatic tool change, I plan to use an atc bt30,
by the way do you think that a servo motor of 1000w 3.3n.m 3000rpm is a good option to cut steel and aluminum? or this very small?, would use shallow depth, I hope I can guide in advance thank you very much friends
« Last Edit: December 02, 2022, 11:24:34 PM by Tweakie.CNC »
