Hello Guest it is November 23, 2026, 03:30:13 AM
Author Topic: Problem with 2.56  (Read 10149 times)
Problem with 2.56
« on: October 31, 2007, 12:47:44 AM »
Is anyone else having problems with I&J's on 2.56?  I reverted install back to 2.02 and all works fine?  The problem is it will not display tool path.  It will not even display the toolpath for a part I have been milling for some time?  Weird... something about arc beginning and end.  Great package though... (Mach 3, NF, LC).
I will keep an eye out for the next update...
Robert
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Problem with 2.56
« Reply #1 on: October 31, 2007, 02:59:02 AM »
check IJ mode is set as you require it on config/general config. I usually have it set to absolute but noticed 2.56.1 had reset it to incremental.
« Reply #2 on: October 31, 2007, 11:20:49 AM »
Thanks... That seem's to have cured it...
Robert
