Mach Discussion => General Mach Discussion => Topic started by: az7733 on October 31, 2007, 01:47:44 AM
Is anyone else having problems with I&J's on 2.56? I reverted install back to 2.02 and all works fine? The problem is it will not display tool path. It will not even display the toolpath for a part I have been milling for some time? Weird... something about arc beginning and end. Great package though... (Mach 3, NF, LC).
I will keep an eye out for the next update...
Robert
check IJ mode is set as you require it on config/general config. I usually have it set to absolute but noticed 2.56.1 had reset it to incremental.
Thanks... That seem's to have cured it...
Robert
