Hello Guest it is November 13, 2026, 02:02:43 PM
Author Topic: Control spindle speed with Mach3  (Read 54076 times)
« on: October 08, 2022, 03:43:48 AM »
Hello everyone
I would like to install a spindle on a CnC I bought second hand.
I have first CnC experience with the Dremel CnC, but am otherwise
inexperienced and new with Mach3.
I would like to install the following spindle:
https://www.aliexpress.com/item/32325323186.html?spm=a2g0o.order_list.0.0.22ab1802ycUMve
The unit would need to be controlled with the analog 0-10V signal.
The cnc is run by a triple beast board. The Triple Beast has a 0-10V output:
https://www.upload.sorotec.de/doku/manuals/TripleBeastBOB-Installation.pdf
In Mach3 (R3.043.062 - Demo) I made the following settings:
(pictures attached)
Output Signals:
- Motor Output: Enabled Step Pin 1, Dir Pin 1, Step Port1, Dir Port 1
- Output #1 Enable Port 1 and Pin Number 17
- Spindle Setup: Relay Control M3 and M3 Output #1 (hack removed)
Motor Control: Use spindle Motor Output, PWM Contorl, PWMBase 250,
Minimum 0%
I've gotten to the point where I can turn the spindle on and off in Mach3.
If I use my VC276TRMS
(https://www.amazon.de/Voltcraft-VC-8235910-VC276-TRMS-DMM/dp/B07DKSW9N5)
measure the output, it only measures 0 or 10 volts.
It never comes out 5 or 6 volts. If I understand it correctly,
it should.
When I connect the spindle, does it not adjust the speed when I go to
adjusted when I set it to 20% or 50% in Mach3. It turns with
full speed.
Does anyone have any ideas?
Re: Control spindle speed with Mach3
« Reply #1 on: October 08, 2022, 04:21:53 AM »
That appears to be a spindle controller, not a spindle!  What spindle are you using?
My understanding is that the PWM signal is generated digitally and there is a trade-off between precision and rate.  I think if you read the documentation carefully they recommend a rather low frequency, more like 25Hz than 250.  Hopefully the filter in the BoB will have a long enough time constant to smooth this - I would check but that manual is in German.
Look out for isolation between the BoB and the controller.  If you haven't already had a "magic smoke" moment is is probably OK, but some motor controllers do not have an isolated control input because the 0v line in the controller floats at mains voltage.  Some BoBs incorporate isolation.
« Reply #2 on: October 12, 2022, 01:19:22 PM »
Hi John
Thank you for your help and sorry for my late answer.
I posted an answer but probably forgot to publish and now I dont find it anymore.
The spindle I am using whith the controller I linked is this one: https://de.aliexpress.com/item/32341418790.html?spm=a2g0o.order_list.0.0.285c5c5fUByh7k&gatewayAdapt=glo2deu
I actually kinda figured it out. there are pin connectors which need to be connected correctly.
Altought it works now, the BoB goes into emergency error sometimes when I turn on the spindle.
Well ... I am getting there. step by step.
Thx again. Take care.
« Reply #3 on: October 12, 2022, 01:58:16 PM »
Glad it's working.  Sounds like an electrical spike is getting into the estop wiring from the spindle perhaps.
« Reply #4 on: October 12, 2022, 02:18:59 PM »
Yeah, this might be it. I will try with real g-code and see it its an issue or not.
« Reply #5 on: December 05, 2022, 12:40:00 PM »
hello, can someone help me? I have vfd chinese inverter AE200H and 5 axes breakout board db25 with 0-10v control. How to connect it, which pins from bob must be connected to vfd?
« Reply #6 on: December 05, 2022, 12:43:03 PM »
« Reply #7 on: December 05, 2022, 12:52:00 PM »
Yes but i cant find where connect p17, and pwm and do i need something else, i know 0-10v go to FV and com.
« Reply #8 on: December 05, 2022, 12:58:01 PM »
Can't say without decent documentation on the BoB.  Does it just output PWM of is there an internal filter?
« Reply #9 on: December 05, 2022, 01:06:34 PM »
I dont know, i need help. This is link of bob, in downloads have datasheet
https://www.vallder-rs.com/sr/c-sr/300/38/kora%C4%8Dni-motori-drajveri/mach3-5-axis-board-detail#details
