Hello Guest it is November 13, 2026, 12:00:15 PM
Author Topic: Control spindle speed with Mach3  (Read 54069 times)
Re: Control spindle speed with Mach3
« Reply #10 on: December 05, 2022, 01:12:18 PM »
See page 3 of the manual for wiring diagram.  Page 7 shows the spindle setup including setting the PWM base frequency.
« Reply #11 on: December 05, 2022, 01:15:30 PM »
Ok but what connect from bob and where to vfd? How to know this
I mean which pins must be connected for both side
« Reply #12 on: December 05, 2022, 03:04:36 PM »
You'll just have to read the manuals.  It isn't hard.
« Reply #13 on: December 05, 2022, 05:48:46 PM »
What I'm asking is not in the manual, and I can't find a query to connect these two things.
If anyone knows, please help me
Offline reuelt
  •  520 520
« Reply #14 on: December 05, 2022, 08:18:12 PM »
If you are using the 5-Axis BOB, jumper for relay must be shorted. Relay is controlleed by Pin 17. Relay Closed when P17 is active.
Relay output connect to FOR and DCM of VFD (TOP ROW in picture)
0-10V output connect to VI of VFD and Analog Ground to ACM. (Bottom ROW in picture). Activated by Pin 1
You need a small 0.1uF capacitor between VI and ACM. Also the two wires must pass thru a ferrite core.
Set the VFD control function to external analog input.
« Last Edit: December 05, 2022, 08:32:07 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
« Reply #15 on: December 05, 2022, 08:50:12 PM »
Confirm Mach3 configurations
