Hello Guest it is October 24, 2026, 08:53:13 PM
Author Topic: Editing loaded GCode???  (Read 6285 times)
Offline Rimmel
  •  284 284
« on: September 28, 2022, 07:52:38 AM »
I know this seems very basic, but in Mach3 mill I could load a Gcode file and change it if needed.
With Mach4 I can't seem to find that option. I have to unload the Gcode (load a different Gcode file) and edit it with an external editor.
Am I missing something?
thanks
Edit: found it hidden away - very unintuative
« Last Edit: September 28, 2022, 08:00:00 AM by Rimmel »
Re: Editing loaded GCode???
« Reply #1 on: September 28, 2022, 08:08:19 AM »
On the standard screen sets look in the lower right corner for the Ops panel. Select the File Ops tab and select the Edit G-code button in the left column.
Steve Stallings
www.PMDX.com
« Reply #2 on: October 02, 2022, 09:41:51 PM »
It combined with the other Gcode File Operations......which seems logical to me. If you were doing it where would you put the button?
Of course Mach4 has an editable GUI so you can in fact put whatever button or gadget wherever you like, so have at it. I'm curious where you would
put it?
