Hello Guest it is October 21, 2026, 07:51:43 AM
Author Topic: strange but true...wierd axis confusion by mach3  (Read 11874 times)
« on: October 29, 2007, 01:22:43 AM »
got a strange one for ya...trying mach3 with my logitrol electronics.  Mach 2 worked fine...but with mach3, well...
I go into the plasma program of mach3, but just my x axis is nonresponsive.  Then I go into the mill program and the situation is reversed...just my y axis doesn't work.  My pins seems correct for both...i'm out of solutions...apprieciate any advice...the program looks great!
ps   also checked any disabiling options in settings/diag screens and switched cpu...thanks again :)
« Last Edit: October 29, 2007, 01:27:22 AM by steelroot »
Re: strange but true...wierd axis confusion by mach3
« Reply #1 on: October 29, 2007, 03:40:00 PM »
Please post your xml files for both plasma and mill and maybe I can find something wrong. You will need to rename then to post them here as the forum will only allow a file name to be posted once.
« Reply #2 on: October 29, 2007, 07:35:00 PM »
i'll get that posted for you...thanks hood...
I tell ya, the problem look so simple to solve since the issue reverses between programs...never know right
Also...this is fun...on the mill program my y axis performs as a z axis...thanx again
« Last Edit: October 29, 2007, 07:45:09 PM by steelroot »
« Reply #3 on: October 30, 2007, 03:56:50 PM »
i have something new...i implanted mach2mill xml file into the mach3 platform and now i am seeing some success...i'll keep updating this to see where it goes...
« Reply #4 on: October 30, 2007, 04:19:31 PM »
You cant use the Mach2 xml for Mach3, they are not compatible. You have to manually eneter the settings in Mach3 for the first time. After that any upgrades you do your settings will stay intact.
