Hello Guest it is October 24, 2026, 09:45:49 PM
Author Topic: Mach 3 USB version  (Read 65647 times)
Mach 3 USB version
« on: July 29, 2022, 12:01:04 PM »
I've built two CNC machines to run on parallel circuits. Is there a version of Mach 3 for USB (serial) cables?
Re: Mach 3 USB version
« Reply #1 on: July 29, 2022, 01:22:59 PM »
Yes but you need a USB connected motion controller such as the UC100 from cncdrive.  This has a Mach3 plugin that allows Mach3 to drive it.  I have a lathe and mill both of which use the uc100.  Initially I used them with the same xp pc I used with the parallel port but now use a win10 mini machine.  I didn't even need to redo the ports&pins config!  The uc100 is built into the shell of a db25 connector and plugs directly into the breakout board. The usb cable plugs into a miniature socket on the back of the shell.
« Reply #2 on: July 29, 2022, 03:40:51 PM »
Thank you very much. I may come back for more as I investigate UC100.
« Reply #3 on: July 29, 2022, 04:01:58 PM »
Happy to help. If you go this route make sure you get the genuine uc100 as there are clones that don't work very well with no support.  There is a good cncdrive support forum and I've found the company very responsive.
http://cncdrive.com/UC100.html
« Reply #4 on: July 29, 2022, 04:12:50 PM »
Thank you again. Before you replied I went to their site and saw their strict warning about the clones. But... as far as I can tell, there's no way to purchase one. There's not even a price listed. I sent them an email about it. On another subject but still having to do with my original post, do all breakout boards use a parallel port input so that you either have to have a parallel ported PC or a UC100?
« Reply #5 on: July 29, 2022, 04:32:06 PM »
http://shop.cncdrive.com/  ??
It looks like you must be on US east coast?  I'm sure they have agents in the US even if they can't ship direct.
« Reply #6 on: July 29, 2022, 05:15:26 PM »
The link you posted above (http://shop.cncdrive.com//) takes me to their products page but the UC100 is not shown there. Just curious-- how did you know I was on the east coast (actually in the SE)?
« Reply #7 on: July 29, 2022, 05:17:49 PM »
I found it. It was listed in the controller subcategory.
« Reply #8 on: July 29, 2022, 05:17:57 PM »
beware that there is many a Chinese knock-off UC100 on Amazon and Ebay. If you are going to buy a UC100 make sure its the genuine
article, the Chinese rip-offs are not a patch on the real thing.
Depending also on your electrical environment you may find USB to be subject to electrical noise and fail in service. A very short USB cable is required, a long cable is inviting
trouble. In this regard Ethernet connected motion controllers are much better, for instance the UC300 which is also made by CNCDrive.
« Reply #9 on: July 29, 2022, 05:18:53 PM »
Still curious to know: Do all breakout boards use a parallel port input so that you either have to have a parallel ported PC or a UC100?
