Hello Guest it is October 25, 2026, 01:11:13 AM
Author Topic: E stop won't reset on mach3  (Read 22159 times)
Offline Jackal
  •  173 173
« on: July 16, 2022, 12:43:12 PM »
Hello,
I have a Hurco mill that was retrofitted in 2011.
It has ran great over the years.
After sitting idle (no power) for about 5 months,when I power it on the Estop won't  reset.
Both Estop buttons and wiring check ok.
The Estop light on my control panel stays lit up, and the main screen 'reset flashes'.
It has been so long since  I've  messed with the pins and settings in mach.
Can someone tell me which pins in the settings I can check/reset/ toggle?
Thanks  so much.
Everything is bio-degradable if you run over it enough with a lawnmower.
Offline Jackal
  •  173 173
Re: E stop won't reset on mach3
« Reply #1 on: July 17, 2022, 08:06:53 PM »
Any ideas where to start?
I'm  going to reroute new wire to the Estop switches.
Bypass all the old wires.
Then, check settings on the pins page.
