Hello
Guest
it is
October 25, 2026, 04:03:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
How to hookup spindle?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to hookup spindle? (Read 25693 times)
JBWolf
25
on:
July 08, 2022, 08:23:06 PM »
I am trying to figure out how to get the spindle going with my breakout board and running properly in Mach3.
The board is a KLDB25.
The spindle is a SunFar E300.
What is the best way to physically connect and also how to setup in Mach3?
Thanks!
ZASto
434
Re: How to hookup spindle?
Reply #1 on:
July 09, 2022, 12:33:18 AM »
You will have to reprogram some parameters in your VFD.
Here you can download the manual for VFD:
http://stepdir.ru/komplektuyushie/dlya-frezernyh-stankov/invertory/invertor-sunfar-e300-2s0015l.html
Instead of using multifunction inputs you will have to set that the speed input is set with analog input.
On your BOB you have 0-10V output and according you have to wire it to your VFD.
Read the manual.
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
JBWolf
25
Reply #2 on:
July 09, 2022, 09:21:25 PM »
unfortunately I cannot find a manual for my BOB, but it looks as if every output has an opto-iso... can those run an analog signal for the spindle?
When you say it has a 0-10v output, is that a specific pin cause they all look like the same type
ZASto
434
Reply #3 on:
July 10, 2022, 12:04:00 AM »
Unfortunately, your BOB does not have analog output (PWM).
If you intend to use LPT port, do yu self a favour and buy one of these;
https://www.aliexpress.com/item/32830611064.html?spm=a2g2w.productlist.3.1.30692b5cZiUzzE&sku_id=65015597255&gatewayAdapt=glo2rus
It as a relay to turn the spindle ON/OFF as well as analog output 0-10V
JBWolf
25
Reply #4 on:
July 10, 2022, 03:33:44 AM »
Is that one or a similar one available in the USA, preferably ebay?
ZASto
434
Reply #5 on:
July 10, 2022, 05:00:14 AM »
Just search for "Mach3 5 axis .... "
JBWolf
25
Reply #6 on:
July 10, 2022, 08:33:18 PM »
I got this one...
https://www.ebay.com/itm/174725161345
looks like it converts 5vdc from the USB port for step/dir axis signals.... then it also has 12-24v input for the 0-10v spindle output.
Then I ordered one of these:
https://www.ebay.com/itm/175293058532?var=474511654200
Chose the 24v 2A model
Should be everything I need I hope... yes?
Print
Pages:
1
Go Up
« previous
next »
