Hello Guest it is October 25, 2026, 04:03:30 AM
Author Topic: How to hookup spindle?  (Read 25697 times)
« on: July 08, 2022, 08:23:06 PM »
I am trying to figure out how to get the spindle going with my breakout board and running properly in Mach3.
The board is a KLDB25.
The spindle is a SunFar E300.
What is the best way to physically connect and also how to setup in Mach3?
Thanks!
Offline ZASto
  •  434 434
Re: How to hookup spindle?
« Reply #1 on: July 09, 2022, 12:33:18 AM »
You will have to reprogram some parameters in your VFD.
Here you can download the manual for VFD: http://stepdir.ru/komplektuyushie/dlya-frezernyh-stankov/invertory/invertor-sunfar-e300-2s0015l.html
Instead of using multifunction inputs you will have to set that the speed input is set with analog input.
On your BOB you have 0-10V output and according you have to wire it to your VFD.
Read the manual.
My personality is who I am.
« Reply #2 on: July 09, 2022, 09:21:25 PM »
unfortunately I cannot find a manual for my BOB, but it looks as if every output has an opto-iso... can those run an analog signal for the spindle?
When you say it has a 0-10v output, is that a specific pin cause they all look like the same type
Offline ZASto
  •  434 434
« Reply #3 on: July 10, 2022, 12:04:00 AM »
Unfortunately, your BOB does not have analog  output (PWM).
If you intend to use LPT port, do yu self a favour and buy one of these; https://www.aliexpress.com/item/32830611064.html?spm=a2g2w.productlist.3.1.30692b5cZiUzzE&sku_id=65015597255&gatewayAdapt=glo2rus
It as a relay to turn the spindle ON/OFF as well as analog output 0-10V
« Reply #4 on: July 10, 2022, 03:33:44 AM »
Is that one or a similar one available in the USA, preferably ebay?
Offline ZASto
  •  434 434
« Reply #5 on: July 10, 2022, 05:00:14 AM »
Just search for "Mach3 5 axis .... "
« Reply #6 on: July 10, 2022, 08:33:18 PM »
I got this one...
https://www.ebay.com/itm/174725161345
looks like it converts 5vdc from the USB port for step/dir axis signals.... then it also has 12-24v input for the 0-10v spindle output.
Then I ordered one of these:
https://www.ebay.com/itm/175293058532?var=474511654200
Chose the 24v 2A model
Should be everything I need I hope... yes?
