Hello Guest it is October 24, 2026, 01:37:49 PM
Author Topic: Csmio ENC module - spindle oscillating arround fixed position  (Read 49914 times)
Hi there,
this is my first post in the forum, first of all I'd like to say thanks to all of you for all the useful information you've shared, it's helped me a lot so far.
I'm retrofitting an old CNC machine using a CSMIO/IP-A, consisting on 3 axis driven by servos and a 7kw spindle controlled with a mentor driver. Everything has worked like a charm until I tried to set up the spindle to stop in a given position for auto tool change. After contacting cslabs they suggested using an ENC module for this purpose so I purchased one.
Following this topic https://www.machsupport.com/forum/index.php?topic=31710.50 I successfully made the spindle stop at the right position, but it keeps oscillating no matter what.
This is what I've done so far:
The spindle driver is configured to work with 10v signal which is coming from the csmio/ip-a, and has an encoder attached to the spindle with a timing belt which is connected to both the csmio/ip-a and the ENC module as well (following the advise given in the Enc module topic).
I followed the PID video from cslabs (https://www.youtube.com/watch?v=SD01YNqjmhE&ab_channel=dziabi3 ) for tunning the spindle and it should be correctly tunned (I've tried to decrease the I factor of the PID but it keeps oscillating).
Here's a video of the spindle tuning monitor where you can see the behavior while turning and when stopped:
https://youtu.be/fzY7NdHwBz8
I have tryed to increase the deadband but the spindle keeps oscillating around the fixed position, (deadband=0) oscillation are +-1mm, (deadband=50) oscillations are +-5mm, thas it has any sense to anyone?
Any idea on how to go on solving this issue would be really appreciated.
-Alexandre Oliver-
Re: Csmio ENC module - spindle oscillating arround fixed position
« Reply #1 on: July 13, 2022, 12:22:47 PM »
Here's a video of the actual movement of the spindle: https://youtube.com/shorts/aQ1Sf7ajUzQ
