Hello Guest it is October 25, 2026, 05:32:02 AM
Author Topic: How to setup ARF CNC 6040Z  (Read 24011 times)
« on: June 20, 2022, 01:48:05 AM »
Hello
Have an ARF CNC 6040Z Mach3 that was my dad who suddenly passed away.
He had a hard time getting it to work so I wonder if anyone has the RIGHT settings to send to me so I can start over. He had installed Mach3 on a laptop and I have read that PC is to recommend?
Is there anything else I should think about?
Fredrik
Re: How to setup ARF CNC 6040Z
« Reply #1 on: June 20, 2022, 04:27:08 AM »
So after doing some research you probably have the 6040 with a usb motion control card. If this correct then you first need to install the plugin (RNRMotion.dll) for mach3.I may have my xml from my old setup if you want it to see if you can get something going. that is where I would start.
Regards
Charlie M.
« Reply #2 on: June 20, 2022, 10:17:47 AM »
Hello dude, I have the same question, can someone help to fix this prob?
Hi there. Check best writing service for more details.
« Reply #3 on: June 20, 2022, 10:59:57 AM »
I can try. What's going on
Regards
Charlie M.
« Reply #4 on: June 26, 2022, 06:30:40 AM »
 You gents still need help?
Regards
Charlie M.
