Hello Guest it is October 20, 2026, 03:48:33 PM
Author Topic: White blank screen.  (Read 16395 times)
Offline pumpa
  •  12 12
White blank screen.
« on: October 27, 2007, 01:27:03 AM »
Mach3 problem!!!!
Had Mach3 running fine under xp and i really don't know what i did, but now when i boot up Mach3 mill i just get a white screen.
This doe's not happen with Mach3 turn or Plasma, can someone please shed a bit of light. >:(
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: White blank screen.
« Reply #1 on: October 27, 2007, 03:40:51 AM »
Do you get a window with a white background or is the whole screen white with no window border?
Graham.
Offline pumpa
  •  12 12
« Reply #2 on: October 27, 2007, 03:56:34 AM »
Just a window that mach is displayed in, not the whole screen.
  •  2,785 2,785
« Reply #3 on: October 27, 2007, 04:33:37 AM »
OK,
If the View menu is showing select load screens, then select 1024.set and open
If this dose not fix it then its a reload of mach.
Graham.
Offline pumpa
  •  12 12
« Reply #4 on: October 27, 2007, 06:01:08 AM »
1024.set was a sure fix, i thank you kindly Graham.
I still don't know what i did to bring up the white screen in the first place.
Cheers Lou.
