Hello Guest it is October 21, 2026, 05:55:11 PM
Author Topic: Control Panel Size  (Read 24437 times)
Offline kolias
  •  1,165 1,165
Control Panel Size
« on: May 28, 2022, 02:26:36 PM »
Starting the wiring for my new cnc and the attached shows the box size plus the orientation off the ESS and C11G BOB which I would like to have comments if the arrangement shown is correct or perhaps the 2 boards should be placed different. The 3” high pc for the switches will be 1/8” thick aluminum and under it will be a single 1/8” thick door.
The box is made out of 5/8” thick plywood which I have. I would have liked to make it out of 1/4" or 3/8” ply but the cost of plywood in my area is astronomical! (like anything else…).
Thank you
« Last Edit: May 28, 2022, 02:28:21 PM by kolias »
Nicolas
Re: Control Panel Size
« Reply #1 on: May 29, 2022, 02:22:48 AM »
Should be fine.  1/8 overkill for switch panel unless you happen to have it.
Offline kolias
  •  1,165 1,165
« Reply #2 on: May 29, 2022, 09:07:42 AM »
1/8” is what I have. Let me know if the positions I have of the ESS / C11G BOB are acceptable. Never used ESS before and just wonder
Nicolas
« Reply #3 on: May 29, 2022, 04:19:35 PM »
I can't see it makes much difference provided the wiring is fairly short, position the units to achieve that.
