Hello Guest it is November 07, 2026, 02:07:40 AM
Author Topic: K2 cnc 25x39 mach 2  (Read 146885 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
K2 cnc 25x39 mach 2
« on: April 10, 2006, 03:26:02 PM »
                                -KG-3925-
Footprint with the motors 54" x 30" x 26"
Travel or Cutting dimension:
X-39" Y-24.5" Z-5"
Pulley
Ratio is 2:1 on X and Y
Pulley made of Aluminum
Frame Features:
Structure is CNC machined 6061 aluminum and extrusions
6061 Billet Machined Aluminum
X and Y Axis uses 20mm THK style linear rails/blocks (4 Blocks for X and 2 for Y)
Z Axis Details:
5" Travel comes with Linear Rigid Rails and Hi-Tolerance Ball screw of .001 Tolerance
Servo Controller Details:
3 to 4 Servo Motors with feedback encoders.
Geckodrive G320 servo controller
Wired for Step/Dir signals from Printer/Parallel Port
Fully enclosed control box and prewired for Parallel Interface
110 (std.) or 220 (request) watts power supply. 24VDC unregulated (~30V) 8 Amps.
5 watt power input wire from 1 computer USB port.
Linear Motion of X and Y Axis:
Rigid Rails
Hi-Tolerance Ball screws of .001 backlash tolerance available( bearing house has a plastic dust cover )
Ballscrews .001" backlas tolerance.
305 oz/in Servo.
2:1 Pulley ratio.
Total weight: 190 LBS
Set up by Zealouse (VILE GUITARS)
