Hello Guest it is November 10, 2026, 01:54:58 AM
Author Topic: Mach3 hangs while loading program  (Read 11246 times)
« on: April 03, 2022, 11:55:04 PM »
Hello, everyone
I programmed a macro that turns on an output and then waits for a limit switch. Short pause and the output is switched off again.
The program itself works when I call it.
ActivateSignal(Output4)
While IsActive(Input4)
Sleep100
Wend
Sleep500
DeactivateSignal(Output4)
But if I write the macro in a program so that it runs automatically. Mach3 gets stuck at the position of the macro and waits for the input. If I activate the input, the program is then loaded.
Mach 3 shouldn't get stuck in a loop condition while loading the program.
What can I do against it?
Thanks and best regards
Stefan
Offline TPS
  •  2,627 2,627
Re: Mach3 hangs while loading program
« Reply #1 on: April 04, 2022, 01:29:44 AM »
check
Config -> General Config -> General Configuration -> Ignore M calls while loading
« Reply #2 on: April 04, 2022, 01:43:05 AM »
Thank you.
I've been looking for a solution for days .
Have a nice day
Stefan
