Hello Guest it is November 11, 2026, 08:26:54 PM
Author Topic: Problem with Pokeys 57U  (Read 70439 times)
« on: March 30, 2022, 02:54:52 PM »
Hello
I am trying to migrate from using parallel port to USB.
I have Pokeys57U that is currently wired to a single DM542 drive, just to test the system. Managed to get it working but there is a single issue.
When clicking reset in Mach3, I use keyboard to start jogging and release the key after 1 second. When releasing key, drive locks immediately making a clang sound.
When jogging longer or jogging second time it stops by slowing down normally. When double-clicking reset, drive locking happens again.
What could be the problem?
Thanks for any help!
Re: Problem with Pokeys 57U
« Reply #1 on: June 14, 2022, 04:22:56 AM »
Hi!
How did you connect the DM542 drive to your PoKeys controller? Which pins do you use? Is the device firmware up to date? (I have seen a change from before.)
« Reply #2 on: March 26, 2024, 08:52:45 PM »
Hello
I think this is a problem caused by a system software error.
