Hello Guest it is November 13, 2026, 11:26:49 AM
Author Topic: Mach3  (Read 27372 times)
Mach3
« on: March 28, 2022, 12:26:39 PM »
Hi there i am running Mach3 fully licensed and have change to a new Super USB interface MACH3 100Khz Board 4 Axis Interface Driver Motion Controller recommended by artsoft the trouble i am having is when i run mach 3 in simulation mode it will do thousands of line, when mach 3 is connected to the motion controller it will only do 500 line then stop.
Any help would be good
Pete
Re: Mach3
« Reply #1 on: March 28, 2022, 01:32:37 PM »
You're in demo mode.  Look for your Mach1Lic.dat file and put it in the Mach3 directory.
Re: Mach3
« Reply #2 on: March 28, 2022, 03:15:35 PM »
Hi there i will try that thanks
Pete
Mach 3
« Reply #3 on: April 01, 2022, 06:24:51 AM »
Hi there i have a problem with mach3 running on windows 7 64 bit i have a full licence.
I have now installed a motion controller all works ok but it will not go above 500 line
Re: Mach 3
« Reply #4 on: April 01, 2022, 04:45:34 PM »
Then Mach is in Demo mode. You may have a license but it is not in the right folder or corrupt or something.
Craig.
Offline TPS
  •  2,627 2,627
Re: Mach3
« Reply #5 on: April 03, 2022, 03:44:29 AM »
you need to have a valide  licence file
Mach1Lic.dat
in C:\Mach3
