Hello Guest it is November 11, 2026, 08:27:05 PM
Author Topic: Homing Procedure  (Read 18444 times)
Homing Procedure
« on: March 27, 2022, 01:25:22 PM »
Hello all,
I am using the Pokeys57 cnc ethernet controller with Windows 10.
I do not use home switches.  I would like to disable the auto homing procedure, this way when I press the "ref all home" button the software will set the current machine coordinates as home/zero.
I have set this up in the past to work this way, but that computer crashed in a bad way and I can no longer recall how I had configured the system.
Offline Azalin
  •  191 191
Re: Homing Procedure
« Reply #1 on: March 27, 2022, 02:06:28 PM »
If you are using Mach4 then this should work.
« Reply #2 on: March 27, 2022, 02:29:08 PM »
I am using mach 3
