Hello Guest it is September 05, 2026, 05:45:53 PM
Author Topic: Z axis going the oposite way it should.  (Read 14681 times)
« on: October 23, 2007, 07:09:34 PM »
My Z axis goes the opposite way it should, I always have to switch the values around to make the code work. Can this be fixed in Mach3 or is there something I'm doing wrong when I set up my CAM program to make the G-code?
Re: Z axis going the oposite way it should.
« Reply #1 on: October 23, 2007, 07:17:41 PM »
Z- should be making the tool go deeper into the part. If you jog in a negative direction, is it going deeper? If not you can change the motor direction in config, homing and limts. Reverse the z axis.
« Reply #2 on: October 23, 2007, 07:17:47 PM »
You can reverse the axis in the Homing and Limits page, you will find it under the config menu.
« Reply #3 on: October 23, 2007, 07:40:32 PM »
If I press "page down" on the keyboard the Z axis goes up, if I press "page up" the Z-axis goes down.
Thanks, I'll check that out.
« Reply #4 on: October 23, 2007, 09:05:46 PM »
Does your spindle go up and down on your machine or your table?
« Reply #5 on: October 24, 2007, 12:13:05 PM »
The spindle. Its a Sherline 5400.
« Reply #6 on: October 24, 2007, 01:42:58 PM »
OK so if you press the Pg Down your spindle should go down and your DRO for the Z should increase in the  negative. Is this happeneing?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #7 on: October 24, 2007, 08:33:48 PM »
Hi, mac102004
In Config, Home & Limits there is a Reversed Box for each Axis, Check it for your Z Axis.
Hope this Helps, Chip
