Hello Guest it is September 24, 2026, 08:50:42 AM
Author Topic: Box Joint Wizard  (Read 56535 times)
Box Joint Wizard
« on: March 18, 2022, 06:23:25 AM »
I saw a video on YouTube has this screenset for using making box joint.
https://www.youtube.com/watch?v=EqduHcaTRPI&t=604s
He claimed the Box Joint Wizard by TPS. I did a search for Box Joint Wizard came up empty. Does anyone know where can I find this screen wizard?
Offline TPS
  •  2,627 2,627
Re: Box Joint Wizard
« Reply #1 on: March 18, 2022, 01:23:56 PM »
Hello Willy,
i have made this for a guy named Roy. it is no "classic" wizzard, the screen had been integrated into
his custom screenset.
give me some time, then i will "export" this part into a wizzard.
« Reply #2 on: March 18, 2022, 07:59:59 PM »
Thank you Thomas,
I am looking forward to it.
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 19, 2022, 02:28:06 AM »
ok here we are. unzip the attached file to:
C:\Mach3\Addons\fingercut
the copy the files:
M120.M1S
numerickeyboard.M1S
to C:\Mach3\macros\ your profile name
then you should be able to run the wizzard with Wizzards -> Pick Wizzard
it is very "raw " without any grafics but it should work.
in the macro M120.M1S are the conditions for the program to wait for the next move,
in this case it is waiting for Input1 to go first LOW and then HIGH.
the guy i did this for had a limit switch installed on the support so every time he pushed forward
and came back the program did the next move. you can also put a M1 into it then you have allways to
push Start Button for the next step.
« Reply #4 on: March 19, 2022, 06:19:43 AM »
good morning
I downloaded your "box joint wizard" work installed as described when I launch it it starts but when I go to insert the measures in the DRO I get this error I repeat I put the files
numerickeyboard.m1s
M120.m1s
in c: \ mach3 \ macros \ Mach3Mill
am I wrong something?
Thanks for your help
« Reply #5 on: March 19, 2022, 09:11:23 AM »
Yes I got the same error messages.
« Reply #6 on: March 19, 2022, 09:40:16 AM »
I am starting building my system. I think the error probably is waiting for M1 input.
I am new to Mach3 so lot have to be learned.
Offline TPS
  •  2,627 2,627
« Reply #7 on: March 19, 2022, 09:41:22 AM »
fixed this problem
« Reply #8 on: March 19, 2022, 01:52:54 PM »
Thanks TPS as always great job and always available to help !!! :) :) :)
« Reply #9 on: March 19, 2022, 07:33:58 PM »
Thank you so much TPS.
