Hello Guest it is November 13, 2026, 04:48:19 PM
Author Topic: Box Joint Wizard  (Read 58570 times)
Re: Box Joint Wizard
« Reply #10 on: March 24, 2022, 08:43:59 PM »
Hello TPS,
If I just like to have another screen for with keyboard to enter cut length and DRO display current position. I can design the second screen with Machscreen but have no ideas where to reference the codes.
So I can just as regular table saw with CNC fence system.
Offline TPS
  •  2,627 2,627
« Reply #11 on: March 25, 2022, 02:19:03 AM »
ok, let's say you place a dro for example OEMDro(1250) to your screen.
then you put a transparent button over this DRO and this will excecute the VB Script.
the code for this button would be:
Code: [Select]
Sub Main
Call NumericKeyboard(1250,0,999)
End Sub
#Expand "c:\Mach3\macros\Mach3Mill\numerickeyboard"
with this you should be able to enter a value into DRO 1250
the you place a normal button also with VBscript to do the entire move code:
Code: [Select]
  Code "G1 Z" &GetOEMDRO(1250) &" F200"
and thats it.
