Hello Guest it is November 10, 2026, 01:54:59 AM
Author Topic: ATC FOR CINCINNATI MILL  (Read 31544 times)
« on: January 19, 2022, 10:11:08 PM »
HI I NEED SOME HELP WITH THIS ATC CODE
THE CODE WILL PULL THE OLD TOOL OUT OF THE SPINDLE AND WILL PUT ANOTHER TOOL IN FROM
THE CAROUSEL BUT IT REALY DONT KNOW HOW MUCH TO TURN THE CAROUSEL CW OR CCW SO REALLY IM TRYING TO INSERT A PEASE OF CODE INTO MINE
Re: ATC FOR CINCINNATI MILL
« Reply #1 on: January 20, 2022, 08:48:36 PM »
I TESTED THIS TODAY AND IT TURN CW OR CCW DEPENDING ON TOOL# BUT IT WILL ONLY DO ONE SLOT
Offline TPS
  •  2,627 2,627
« Reply #2 on: January 21, 2022, 03:31:12 AM »
try this
Code: [Select]
''Sequence to determine the least travel to move for TC, CW or CCW
'atp = Actual tool position, rtp = Requested tool positon
'Sub LeastTravel()
NewTool = GetSelectedTool()
OldTool = GetCurrentTool()
NewTool = 10
OldTool = 12
NTool =24 ' Number of tools changer holds
CWPos = NewTool - OldTool ' Assume a CW move
If CWPos < 0 Then ' CWPos < 0 ==> rtp < atp
CWPos = CWPos + NTool
End If
CCWPos = NTool - CWPos
If CWPos < CCWPos Then
Call CW(CWPos)
Else
Call CCW(CCWPos)
End If
'End Sub
Function CW(ByVal Pos As Integer)'Rotation CW
   Dim x As Integer
   ActivateSignal(OUTPUT16)'UnLock Pin
   While IsActive(OEMTRIG12)
   Wend
   ActivateSignal(OUTPUT15)'Turns Carousel CW
   For x=1 To Pos
While IsActive(OEMTRIG11)
Sleep(50)
Wend
While Not IsActive(OEMTRIG11)
Sleep(50)
Wend
Next x
    CTPos=x
DeactivateSignal(OUTPUT15)
Deactivatesignal(OUTPUT16)
End Function
Function CCW(ByVal Pos as Integer)'Rotation CCW
Dim y As Integer
ActivateSignal(Output16)'UnLock Pin
While IsActive (OEMTRIG12)
Wend
Activatesignal(OUTPUT14)'Turn Carousel CCW
For y=1 To Pos
Sleep(50)
Wend
Sleep(50)
Wend
Next y
DeactivateSignal(OUTPUT14)
End Function
« Reply #3 on: January 21, 2022, 10:34:42 AM »
THANKS AGAIN THAT WAS REALY GOOD I DID SOME CHANGES AND IT LOOKS LIKE IS COUNTING BUT IT WILL GO FROM TOOL#1 TO TOOL#9 IF I CALL #8 SO IT IS COUNTING 8 POS
I STILL NEED TO SET RIGHT SLEEP() BEFORE DEACTIVATESIGNAL(14) AND (15) BECAUSE THE PICKTAIL WHERE WE GETTING THE (OEMTRIG11) IS ON THE HYDROMOTOR SHAFT AND IS GOT
45 DEGREES OFF ON BOTH DIRECTIONS BEFORE IT GOES ON FOR 270 DEGREES AND THEN OFF
FOR 45 DEGREES TO THE PERFECT SLOT AND LOCKING PIN POS BUT I THINK IT COULD BE ADJUSTED
LATER
 ''''Sequence to determine the least travel to move for TC, CW or CCW
'Sub LeastTravel()
   'NewTool = 10
   'OldTool = 12
   End If
      Call CW(CWPos)
   Else
      Call CCW(CCWPos)
   End If
'End Sub
   Dim x As Integer
   Wend
   For x=1 To Pos
         Sleep(50)
      Wend
         Sleep(150)
      Wend
   Next x
    CTPos=x
   SetCurrenttool(NewTool)
End Function
   Dim y As Integer
   Wend
   For y=1 To Pos
         Sleep(50)
      Wend
         Sleep(150)
      Wend
   Next y
   SetCurrentTool(NewTool)
End Function
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 21, 2022, 10:45:30 AM »
is OEMTRIGGER(11) on or off if the carousel is in position for locking?
Offline TPS
  •  2,627 2,627
« Reply #5 on: January 21, 2022, 12:00:28 PM »
on your youtube video it looks like the lock pin is retracted earlier so the carousel will "snap in" if it reaches
final position.
« Reply #6 on: January 21, 2022, 03:58:40 PM »
WELL IS WORKING GOOD THANKS SO MUCH SO HAPPY
NOW IM GOING TO TRY INSERTING THE TOOL ARM CODE TO THIS ONE
'''''Sequence to determine the least travel to move for TC, CW or CCW
'Sub LeastTravel()
   End If
      Call CW(CWPos)
   Else
      Call CCW(CCWPos)
   End If
'End Sub
   Dim x As Integer
   Sleep (200)
   Wend
   For x=1 To Pos
      'While IsActive(OEMTRIG11)
         Sleep(500)
      'Wend
         'Sleep(10)
      Wend
   Next x
    CTPos=x
   DeactivateSignal(OUTPUT16)
   Deactivatesignal(OUTPUT15)
   SetUserDro(1220,NewTool)
   'SetUserDro(1224,NewTool)
End Function
   Dim y As Integer
   Sleep (200)
   Wend
   For y=1 To Pos
         Sleep(500)
      'Wend
         'Sleep(10)
      Wend
   Next y
      CTPos=y
   Deactivatesignal(OUTPUT14)
End Function
« Reply #7 on: January 21, 2022, 04:10:29 PM »
WHEN THE YOU DEACTIVATESIGNAL(OUTPUT16) THE PIN LOCKS THE CAROUSEL JUST A MOMENT BEFORE THAT THE CW OR CCW HYDROMOTOR HAS TO BE OFF, THE PIN HAS SOME KIND OF CAM
THAT WILL CENTER IT IN THE SLOT SO THERE IS ROOM FOR MISTAKE ON THE TIMING THAT IS WHY ON THE VIDEO LOOKS LIKE IT WAS GOING TO KEEP TURNING AND CAME BACK IN PLACE
IM SO THANKFULL FOR WHAT YOU DONE
« Reply #8 on: January 21, 2022, 04:46:29 PM »
FOR NOW IM GOING TO TRY THIS WITHOUT LOOKING AT THE DROS ON THE CAROUSEL
    'CINCINNATI-750 MACH3 CNC SOFTWARE RETROFIT
   Dim OLDTOOL,NewTool,Slot,HomeSensor,Count As Integer
  OldTool=GetCurrentTool()
  NewTool=GetSelectedTool()
  Slot=GetUserDro(1220)
  HomeSensor=(GetOEMTRIG10)
  Count=(GetOEMTRIG11)
  TIS1=GETOEMDRO(1201)       'TOOL IN SLOT
  TIS2=GetOemDro(1202)
  TIS3=GetOemDro(1203)
  TIS4=GetOemDro(1204)
  TIS5=GetOemDro(1205)
  TIS6=GetOemDro(1206)
  TIS7=GetOemDro(1207)
  TIS8=GetOemDro(1208)
  TIS9=GetOemDro(1209)
  TIS10=GetOemDro(1210)
  TIS11=GetOemDro(1211)
  TIS12=GetOemDro(1212)
  TIS13=GetOemDro(1213)
  TIS14=GetOemDro(1214)
  TIS15=GetOemDro(1215)
  TIS16=GetOemDro(1216)
  TIS17=GetOemDro(1217)
  TIS18=GetOemDro(1218)
  TIS19=GetOemDro(1219)
  TIS20=GetOemDro(1230)
  TIS21=GetOemDro(1231)
  TIS22=GetOemDro(1232)
  TIS23=GetOemDro(1233)
  TIS24=GetOemDro(1234)
   If NewTool=OldTool Then
     MsgBox "SAME TOOL"
       Exit Sub
   End If
  If NewTool=TIS1 Or NewTool=TIS2 Or NewTool=TIS3 Or NewTool=TIS4 Or NewTool=TIS5 Or NewTool=TIS6 _
  Or NewTool=TIS7 Or NewTool=TIS8 Or NewTool=TIS9 Or NewTool=TIS10 Or NewTool=TIS11 Or NewTool=TIS12 _
  Or NewTool=TIS13 Or NewTool=TIS14 Or NewTool=TIS15 Or NewTool=TIS16 Or Newtool=TIS17 Or NewTool=TIS18 _
  Or NewTool=TIS19 Or NewTool=TIS20 Or NewTool=TIS21 Or NewTool=TIS22 Or NewTool=TIS23 Or NewTool=TIS24 Then
    CODE "M19"
    GoToSafeZ()
  While IsMoving
  Wend
   Message "TOOL IN CAROUSEL"
  ActivateSignal (Output13)'move tool arm to spindle on
  While IsActive (OEMTRIG9)=0
  Sleep (300)
  Wend
 DeActivateSignal (Output13)'move tool arm to spindle off
 ActivateSignal (Output9)'extend tool arm
 While IsActive (OEMTRIG3)=0
 Sleep (300)
 Wend
 ActivateSignal (Output11)'PBD unlock
 While IsActive (OEMTRIG7)=0
 Sleep (300)
 Wend
 Code "M7"
 ActivateSignal (Output10)'tool arm down
 While IsActive (OEMTRIG5)=0
 Sleep (300)
 Wend
 ActivateSignal (Output12)'move tool arm to carousel on
 While IsActive (OEMTRIG8)=0
 Sleep (300)
 Wend
 Code "M9"
 DeActivateSignal (Output10)'tool arm up
 While IsActive (OEMTRIG4)=0
 Sleep (1000)
 Wend
 DeActivatesignal (Output9)'tool arm retract
 DeActivateSignal (Output12)'move tool arm to carousel off
 DeActivateSignal (Output11)'PBD lock
  Message "Spindle Is Empty"
  SetUserDro(1224,0)
  Sleep (2000)
'Sub LeastTravel()
   End If
      Call CW(CWPos)
   Else
      Call CCW(CCWPos)
   End If
'End Sub
   Dim x As Integer
   Sleep (200)
   Wend
   For x=1 To Pos
         Sleep(500)
      'Wend
         'Sleep(10)
      Wend
   Next x
    CTPos=x
End Function
   Dim y As Integer
   Sleep (200)
   Wend
   For y=1 To Pos
         Sleep(500)
      'Wend
         'Sleep(10)
      Wend
   Next y
      CTPos=y
End Function
   ActivateSignal(Output9)
   While IsActive(OEMTRIG3)=0
   Sleep (300)
   Wend
   ActivateSignal(Output10)
   While IsActive(OEMTRIG5)=0
   Sleep (300)
   Wend
   ActivateSignal(Output13)
   While IsActive(OEMTRIG9)=0
   Sleep (300)
   Wend
   Code "M7"
   ActivateSignal(Output11)
   While IsActive(OEMTRIG7)=0
   Sleep (300)
   Wend
   DeActivateSignal(Output10)
   While IsActive(OEMTRIG4)=0
   Sleep (500)
   Wend
   Code "M9"
   DeActivateSignal(Output11)
   While IsActive(OEMTRIG6)=0
   Sleep (500)
   Wend
   DeActivateSignal(Output9)
   While IsActive(OEMTRIG3) = 1
   Sleep (2000)
   Wend
   DeActivateSignal(Output13)
   Sleep (1000)
   ActivateSignal(Output12)
   While IsActive(OEMTRIG8)=0
   Wend
   DeActivateSignal(Output12)
   End If
  DeActivateSignal(Output17)
  While IsMoving
  Wend
  Exit Sub
  'End If
  'If NewTool<>Slot Then
  'CODE "M19"
  'While IsMoving
  'Wend
  'MsgBox "TOOL NOT IN CAROUSEL"
  'End If
  'SetCurrentTool(NewTool)
  'DeActivateSignal(Output17)
  'While IsMoving
  ''Wend
  'Exit Sub
 End
Offline TPS
  •  2,627 2,627
« Reply #9 on: January 22, 2022, 03:18:49 AM »
the final macro will have to do a couplr more things. did some changes to your code witch might go into right direction. pls use the CODE tab's to post code to keep the formating and keep it readable
Code: [Select]
Dim acttool As Integer
Dim newtool As Integer
Dim Slot As Integer 'Slot is OEMDRO(1220) this will keep position of carousel
Dim HomeSensor As Integer
Dim Count As Integer
Const MaxTool = 24 'MaxTool number
Sub Main()
Slot=GetOEMDro(1220)
'let's do some basic check's
'Get the new ATC Pos
newtool = GetSelectedTool() ' get the newtool
acttool = GetCurrentTool() ' get the acttool
Message "New ATC Position = " &newtool
Sleep(200)
' new and acttool = 0
If ((newtool = 0) and (acttool = 0)) Then
DoButton(1003)
message("new and old tool = 0 -> abort toolchange  !")
Sleep(500)
Exit Sub
End If
' new and acttool are the same
If newtool = acttool Then
message("acttool and newtool are the same -> do nothing!")
Sleep(500)
Exit Sub
End If
'check toolnumber in range
If  (((newtool > MaxTool) Or (newtool < 1)) And (newtool <> 0)) Then
DoButton(1003)
Message (" toolnumber " & newtool & " is not in range (1-" &MaxTool &"). abort toolchange  ! ")
MsgBox  (" toolnumber " & newtool & " is not in range (1-" &MaxTool &"). abort toolchange  ! ")
Exit Sub
End If
CODE "M19"
GoToSafeZ()
While IsMoving
Wend
'only unload tool
If newtool = 0 Then
'turn carousel if not in Position
If newtool <> Slot Then
LeastTravel(newtool)
SetOEMDro(1220,newtool)
End if
'now unload tool
UnloadSpindle
End If
'only load tool
If acttool = 0 Then
If acttool <> Slot Then
LeastTravel(Slot)
SetOEMDro(1220,Slot)
End if
'now load tool
LoadSpindle
End If
'full tool change
If ((acttool <> 0) And (newtool <> 0)) Then
'unload tool
End if
'now unload tool
UnloadSpindle
'load tool
LeastTravel(Slot)
End if
'now load tool
LoadSpindle
End If
SetUserDro(1224,newtool)
SetCurrentTool(newtool)
Code "G43H" & newtool
While IsMoving
Wend
End If
End Sub
Function LeastTravel(ByVal ATCPos As Integer)
   NewPos = ATCPos
   OldPos = GetOEMDro(1220)
   CWPos = NewPos - OldPos ' Assume a CW move
   End If
      Call CW(CWPos)
   Else
      Call CCW(CCWPos)
   End If
End Function
Dim x As Integer
Sleep (200)
Wend
For x=1 To Pos
         Sleep(500)
      'Wend
         'Sleep(10)
      Wend
Next x
    CTPos=x
End Function
Dim y As Integer
Sleep (200)
Wend
For y=1 To Pos
         Sleep(500)
      'Wend
         'Sleep(10)
      Wend
Next y
CTPos=y
End Function
Sub LoadSpindle()
Sleep (300)
Wend
Sleep (300)
Wend
Sleep (300)
Wend
Code "M7"
Sleep (300)
Wend
Sleep (500)
Wend
Code "M9"
Sleep (500)
Wend
Sleep (2000)
Wend
Sleep (1000)
Wend
Message "Spindle loaded"
Sleep(200)
End Sub
Sub UnloadSpindle()
Sleep (300)
Wend
Sleep (300)
Wend
Sleep (300)
Wend
Code "M7"
Sleep (300)
Wend
Sleep (300)
Wend
Code "M9"
Sleep (1000)
Wend
Sleep(200)
End Sub
